Centralized plug-in valve - Parker Hannifin
The centralized Isys Micro is an easy to install and use plug-in valve system designed to let users choose from various installation configurations.
The centralized Isys Micro is an easy to install and use plug-in valve system designed to let users choose from various installation configurations, communications protocols, and override systems when building compact pneumatic systems. The valve’s metal subbase can be fitted with up to four valves. The compact back-to-back design uses four solenoid valves in each 42-mm-wide slice producing up to eight functions/module. The valve uses front or bottom-ported modules and requires no individual wiring. The valves also feature Wear Compensating Seal Technology, which can achieve 50 million cycles.
Parker Hannifin, 6035 Parkland Blvd., Cleveland, OH 44124, (216) 896-3000, www.parker.com
