The Model LT25 linear cable transducer provides digital position and speed feedback information in a rugged, easy-to-install package. The transducer uses a flexible nylon-coated stainless-steel measuring cable mounted to an internal spring-loaded spool and a quadrature encoder output to precisely measure linear motion. The IP66-rated cable has a measurement range up to 125 in. Installation is simple: Connect the LT25 cable to moving equipment and secure the base to a fixed object. The cable transducer allows for easy reorientation of the mounting bracket or encoder connector position.
BEI Industrial Encoders, 7230 Hollister Ave., Goleta, CA 93117, (800) 350-2727, www.beiied.com
