Building a better weed whacker
July 13, 2006
Anyone familiar with gas-fired grass trimmers has probably dealt with the problems associated with using monofilament line as the cutter: it breaks easily, can get tangled when replacing, and gives operators little control in precisely edging a lawn.
Monofilament can also have a tough time getting through heavy
weeds, vines, and light brush. Engineers at Aero-Flex, Rock Hill, S.C. (aero-flex.com), took a new approach, designing an airfoilshaped Flexible Line Blade. Four such blades and a special hub, the Mach 4 Trimming System, replace round monofilament lines. The blade's shape reduces drag through air and grass, convertingwasted power into better cutting. The blades are also heavier, so they last up to 20 times as long as monofilament, and will let manufacturers build trimmers that operate at lower speeds, thus saving gas. Trimmers equipped with the cutting airfoils are also quieter and generate fewer emissions.
