Brush DC Servo Driver
June 2, 2005
The EZSV10 measures 0.95 1.4 0.6 in. (24 35 15.24 mm) and requires little to no tuning when used with most motors measuring less than 1.5-in. diameter.
A single four-wire bus (two power, two comm) provides connections for up to 16 units simultaneously. High-level commands accepted via serial port controls brushed dc motors up to 1.5 A continuous at 12 to 40 V. The system also executes commands in standalone operation using an onboard EEPROM for program storage. Its industry-standard communication protocol is compatible with devices that use the Cavro DT or OEM protocol.
AllMotion Inc.
5501 Del Oro Court
San Jose, CA 95124
(408) 460-1345
allmotion.com
