How small can you go?
Sept. 2, 2004
A 10-bit magnetic rotary encoder...
The AS5040 10-bit magnetic rotary encoder integrated circuit measures 5.3 x 6.2 mm and can measure rotational speeds to 10,000 rpm with incremental outputs.
A 10-bit magnetic rotary encoder from austriamicrosystems, Raleigh, N.C. (www.austriamicrosystems.com), fits in a package less than 35 mm2. It combines magneticfieldsensing Hall-effect elements with an analog front-end and digital signal processing.
The AS5040 is a noncontact encoder system that uses a small, diametrically magnetized magnet above or below the chip to detect 1,024 positions through 360°. It provides absolute, incremental, and PWM digital output signals simultaneously. Incremental output modes include quadrature A/B, single channel, and U-V-W commutation signals. A user-programmable index/zero position measures rotational speed. An SSI port provides absolute position data. It can be custom configured by programming an on-board, one-time-programmable internal register.
Units measure 5.33 x 6.2 mm in an SSOP-16 package and have an operating temperature range from -40 to 125°C. An internal voltage regulator lets units operate at either 3.3 or 5 V. The small size and wide temperature range make it suitable for harsh environments. Automotive and industrial applications include motion control for brushless motors, robotics, and steering and sensing in vehicles.
April 29, 2024
