12-Channel flexible output power supply
Sept. 13, 2007
The APS600/800Rx-N Series of 600-to-800-W switching power supplies come in multiple packaging options including U-frame (8 x 4.4 x 2.5 in.), top cover (8 x 4.4 x 2.5 in.), end-mount fan (9.2 x 4.3 x 2.5 in.), and top-mount fan (8 x 4.4 x 3.3 in.) Output voltage is factory set in the range from 12-to-60 Vdc.
All supplies have standard features of a universal ac input range with active power-factor correction, remote sense, remote on/off control, power good signal, current monitor, and over voltage, current, and temperature protection. The supplies are safety certified to UL60950-1/ TUV EN60950-1 and bear the CE Mark (low voltage directive) with FCC/EN55022 Class-B emissions.
Advanced Power Solutions, 7079 Commerce Circle, Pleasanton, CA 04588, (925) 734-3060, advpower.com
