Coreless Dc-Brush Motors Offer Power and Compact Size
Jan. 9, 2009
Athlonix motors from Portescap, a Danaher Motion Co. based in West Chester, Pa. use a coreless design with a self-supporting coil
Athlonix motors from Portescap, a Danaher Motion Co. based in West Chester, Pa. (portescap.com), use a coreless design with a self-supporting coil and magnetic circuit to deliver maximum power density over the life of the motor. Output power is rated at 9 W and scales with motor frame size, which are available in 12, 16, and 22-mm diameters. The motors weigh between 15 and 53 gm, depending on frame size.
Most self-supporting-coil motors have turn-density limitations which affect magnetic-flux density in the circuit and limit power output and endurance. Althonix’s design maximizes magnetic flux and turndensity for a given diameter. Energy efficiency of these motors approaches 90%.
They also have a motor regulation factor 5 to 20% lower than comparative motors. A lower regulation factor means less heat is lost at high loads, thus letting the motor retain power density over its life despite sustained loads.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
