Swivel Caster Feature locking swivel and wheel
March 5, 2019
The Flexello Series 55 Series of swivel casters can move medium-to-heavy loads over rough floors and in difficult environments.
The Flexello Series 55 Series of swivel casters can move medium-to-heavy loads over rough floors and in difficult environments. The pressed-steel casters feature a formed-leg design for added strength. They are ideal for use on industrial carts and mobile tables, heavy-duty machinery, aviation and aerospace stands. The casters are available in wheel diameters of 6 and 8 inches with either rubber-on-cast-iron or polyurethane-on-cast-iron wheel materials. The 6-in. wheels’ overall height is 7-3/4-in.; swivel radius is 4-3/8-in.; tread width is 1-3/4-in.; and dynamic load capacities of 814 lb. for rubber tires and 1,386 lb. for polyurethane tires. 8-in. wheels’ overall height is 9-5/8-in.; swivel radius is 6-in.; tread width is 2-in.; and dynamic load capacities of 1,177 lb. for rubber tires and 1,595 lb. for polyurethane tires.
The Revvo Caster Co., 888-883-3596.
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
