The GN 1580 Stainless Steel Nuts are certified according to European Hygienic Engineering and Design Group guidelines, making them ideal for use in hygienic areas. “The sealed flange surface lets components be mounted without dead spaces. The high quality finish, as well as the large corner radii and closed surfaces, prevent dkirt crom sticking to them and make cleaning easier and faster. They are available in a matte or polished finish. The FDA-compliant sealing ring is made of a hydrogenated acrylonitrile Butadiene rubber and withstands temperatures from -13 °F (-25 °C) to 302 °F (150 °C).
JW Winco, (800) 877-8351,
