Cicoil_Coax_Cable_Photo
Flat Coax Cable Handles Heat and Cold
Jan. 25, 2019
Standard 30 AWG Coax Cables from Cicoil are available in 50- and 75-Ω with 1 to 8 coax conductors. Unlike most coax cables, these are designed for tight routing installations, continuous motion, phase stability. They also withstand excessive heat (329°F) and extremely cold bend temperature exposure (-85°F), making them well-suited for military, aerospace, medical, marine, and communication applications. The flame-resistant cables contain no halogens, offer space & weight savings advantages, and provide unparalleled reliability in mission critical applications. They are made using an extrusion process that individually encases conductors so they fit in a small flat cable with precisely controlled spacing of each conductor, it insulation, and overall cable shape. The durable cables selfheal after small punctures and will not wear, crack or deform during a lifetime of more than 10 million flexing cycles or long-term exposure to constant motion, vibration, corrosion, water, steam, shock, sunlight, radiation, operational stress, autoclave, humidity, ozone, UV light and many chemicals. The cables are available in continuous lengths, break-outs, custom formed shapes, cut to order, or as fully terminated assemblies. They are UL Recognized, CE Conforming, RoHS & REACH Compliant, Class 1 Clean Room Rated and are cured continuously, with no debris or material contamination in an automated, climate-controlled environment.
Cicoil: (661)-295-1295, www.cicoil.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
