Linear belt drives and actuators
Nov. 3, 2011
A full line of off-the-shelf and plug-and-play linear belt drives and actuators are now available. The plug-and-play models include an actuator
A full line of off-the-shelf and plug-and-play linear belt drives and actuators are now available. The plug-and-play models include an actuator, motor, and PLC for out-of-the-box operation.
Standard and plug-and-play belt-driven actuators let users configure products through options including single or double-shaft types, preferred driveshaft location, and a number of standard travel lengths up to 2,242 mm. These options provide accurate, durable, and maintenance-free solutions for linear-motion applications.
The belt drives and actuators come in 184 to 2,242-mm travel lengths, maximum speeds of 1,270 to 15,240 mm/sec, and load capacities of 25 to 2,500 lb. The belt drives provide 100 to 2,500 lb of force.
Isotech Inc.
777 Schwab Rd., Suite T
Hatfield, PA 19450
(800) 314-3332
www.isotechinc.com
© 2011 Penton Media, Inc.
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
