Semiconductor manufacturer, America Semiconductor, LLC, has released its high-voltage, Schottky rectifier modules. The avalanche energy rated AK2S200-170 modules combine two fully independent
Machinedesign Com Sites Machinedesign com Files Uploads 2014 10 Amer Sem Schottky Rectifier Modules High Res
Semiconductor manufacturer, America Semiconductor, LLC, has released its high-voltage, Schottky rectifier modules. The avalanche energy rated AK2S200-170 modules combine two fully independent diodes into a compact, insulated, SOT-227 package. The 200 Amp (100 Amp per diode), single-phase modules feature a low forward voltage of 0.63 V and repetitive peak reverse voltage of 170 V. The module has a low leakage current, high blocking voltage, and high maximum operation and storage junction temperature of 150°C. It is engineered for a wide range of applications including the output rectification stage of welding machines; switchmode power supplies (SMPS); freewheeling diodes; and, DC/DC converters. The parts’ low recovery current and optimized storage charge reduce the dissipation in the switching elements and EMI/RFI.
America Semiconductors, LLC, 2525 Brunswick Ave., Suite 209, Linden, NJ 07036, (908) 810-7364
