The high-pressure VFD190 Series flow-control valve regulates motor or cylinder speed. Large 1-in. port and optimized design provides low-pressure drop, cutting heat generation and fuel consumption. The three-port variable priority flow divider is immune to rapid changes in load. Adaptive pressure compensation allows regulated and bypass flows to be used to drive separate circuits. The in-line VFD190 is rated to 50-gpm inlet flow, at pressures to 6,000 psi.
Webtec, 1290 E. Waterford Ave., Milwaukee, WI 53235, (800) 932-8378
