High-flow poppet valves
Aug. 26, 2014
The EGV Series high-flow poppet valves are electronically piloted versions of the company’s GV Series valves.
The EGV Series high-flow poppet  valves are electronically piloted versions of the company’s GV Series valves. The valves come in 1/8-in. NPT ported and manifold mount and use 10 or 15-mm valves. Numerous voltage and connection options are available. These two and three-way valves provide 10 times more flow than the company’s MAV Series and 2.5 times more than the MJV Series. An externally piloted option is available for controlling lower pressures or other media.
Features of the small, lightweight valves include electroless nickel-plated brass and hard-coat anodized aluminum construction for long life and corrosion resistance and a proven poppet design.
Clippard Instrument Laboratory Inc., 7390 Colerain Rd., Cincinnati, OH 45239, (513) 521-4261
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
