Timing belt
Aug. 26, 2014
FHT profile timing belts offer high-accuracy and low-maintenance linear motion for 3D printers.
FHT profile timing belts offer high-accuracy and low-maintenance linear motion for 3D printers. The belts deliver smooth operation for the critical linear movement and positioning functions in 3D printers. The timing belts come in various durometers, sizes, and reinforcements such as Kevlar, polyester, and fiberglass.
Advantages of the urethane belts include positive, no-slip synchronization, clean, nondusting performance, and long, low-maintenance life.
Fenner Precision, 250 S. Penn St., Manheim, PA 17545, (800) 327-2288
Granite Motion Systems for Precision Automation
Feb. 7, 2025
PI Granite Based Motion Systems. We provide custom Engineered Multi-Axis Precision Automation Systems, built to your specifications– quick turnaround
Feb. 7, 2025
Flexible Multi-axis Granite Motion System for System Integrators and Machine Builders
Feb. 7, 2025
PI’s X-417 multi-axis positioning system / multi-axis stage is a granite motion system for high speed, high precision automation. Preconfigured with a granite base and EtherCat...
Laser Beam Steering Solutions, Fast Steering Mirrors
Feb. 7, 2025
Fast Laser Beam Steering Mirror (FSM) | Piezo Steering Mirrors | Voice Coil | Tip/Tilt Mirrors, Frictionless Flexures, High-Speed Piezoelectric Drives
