Differential pressure transmitters
Aug. 26, 2014
The PX2600 Series of rangeable, very-low differential pressure transmitters can output either static (gauge) or differential pressure.
The PX2600 Series of rangeable, very-low differential pressure transmitters can output either static (gauge) or differential pressure. The transmitters have four unidirectional and four bidirectional ranges, three selectable outputs (0 to 5 Vdc, 0 to 10 Vdc, and 4 to 20-mA two wire), pushbutton or remote zero, and a four-digit LCD that shows either static or differential pressure. The device comes with a durable glass-filled polyester case.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (800) 826-6342
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
