The S18DLH and S22DLH high-intensity indicator lights are designed with highly visible LEDs to provide bright, clear indication in environments with high levels of ambient light, including direct sunlight. The indicators are dc operated and come in terminal-wired or cabled models in 18 and 22-mm housings. The single-color LED barrel-mount indicators are for stand-alone use or enclosed in a panel. The indicator’s gasket-face flange seals to enclosures and its IP69K-rated housing allows for use in a variety of washdown applications.
The lights are available in white, red, yellow, green, and blue. Bracket mountings include right-angle with curved slot, swivel with tilt and pan movement, and flat and right-angle with articulation slots.
Banner Engineering Corp., 9714 Tenth Ave. N, Minneapolis, MN 55441, (888) 373-6767
March 18, 2025
March 18, 2025
March 18, 2025
