Coil-cell holders
March 25, 2014
Coil-cell holders
Ultralow profile holders for #2032 lithium coin cells are designed for applications where circuit-board height is a critical design parameter. The holders rise only 2 mm above the PCB surface and retain cells securely under shock and vibration in high-density applications.
Height reduction is achieved by partially mounting the holder through a hole in the PCB, allowing the holder to sit through the PCB.  Built-in stabilization tabs in the LCP, UL 94V-0 base add mounting security and gold-plated contacts increase PCB and solder-joint mounting strength.
The holders feature dual-spring contacts and come in bulk and on tape and reel.
Keystone Electronics Corp., 31-07 20th Rd., Astoria, NY 11105, (800) 221-5510
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
