Long ionizing bars
Feb. 11, 2014
Long ionizing bars
Long ionizing bars eliminate static electricity on paper, film and plastics that are up to 96-in. (2,438-mm) wide. The profile of the electrically powered ionizing bar allows it to fit in the confined spaces of machinery, where the static charge is generated. A high concentration of positive and negative ions produce fast static decay, neutralizing any surface within 2 in. (51 mm) of the bar. Insertion molded stainless-steel ion emitters extend life expectancy.
Exair Corp., 11510 Goldcoast Dr., Cincinnati, OH  45249, (800) 903-9247, www.exair.com/lib.htm
