E-stop, pushbutton control stations
Oct. 28, 2013
The Series BDF200 control stations have a slim design that permits mounting on a machine door frame for ease of operation.
The unit’s IP65-rated, shock-resistant enclosure is dust and watertight, and can be quickly and smoothly fitted onto the an aluminum profile system. Each BDF200 can accommodate up to four control elements: E-stop buttons with or without a protective collar; pushbuttons, mushroom buttons, illuminated pushbuttons, and LED indicator lights available in several standard colors; and selector and key selector switches with latched or spring return actuation
Schmersal Inc., 660 White Plains Rd., Suite 160, Tarrytown, NY 10591, (914) 34-4775, http://www.schmersalusa.com
