The PMK (Parallel Mount Kit) allows virtually any motor to be connected in parallel to any linear ball-screw actuator. The unit saves space because the motor is to the side of the actuator.
Available in four standard frame sizes from 3 up to 6 in., the PMK’s maximum output torque is from 2.4 to 46 Nm in a 1:1 pulley transmission ratio. The cover plate is made from aircraft-grade aluminum and anodized for further protection. The pulleys feature conical taper bushings and are connected with a high-torque rubber timing belt for smooth operation.GAM Gear, 901 E. Business Center Dr., Mount Prospect, IL 60056, (888) 426-7117, www.gamweb.com/linear-mounts-main.html
Aug. 29, 2024
Aug. 28, 2024
