Gear drive with inching-drive option
Aug. 23, 2012
The Falk V-Class gear drive is designed for maximum uptime and durable performance.
The Falk V-Class gear drive is designed for maximum uptime and durable performance. The gear drive offers reliable full-load inching for slowspeed operation of equipment for inspection and maintenance purposes. It can also run continuously to prevent freeze-up of components in harsh and cold weather when facilities are not in production.
The inching drive uses a Falk Ultramite gear drive mounted to the main gear drive unit coupled via an overrunning clutch. This lets the inching drive automatically disengage when the main motor is operating.
Rexnord Corp.
4701 W. Greenfield Ave.
Milwaukee, WI 53214
(414) 643-3000
© 2012 Penton Media, Inc.
