Diaphragm metering pump
April 9, 2013
The FMM80 solenoid-driven diaphragm metering pump accurately dispenses liquids in adjustable volumes between 30 and 80 –l/stroke.
The FMM80 solenoid-driven diaphragm metering pump accurately dispenses liquids in adjustable volumes between 30 and 80 –l/stroke. The pump can be driven with single impulses to deliver discrete microvolumes or operated with a pulsed signal at a frequency up to 10Hz to provide continuous flow rates to 48ml/min.
The pump offers more than 500million strokes, uses a noisesuppression system for quietrunning operation, remains flow-tight in both directions with pressures of 14.5 psig at rest, exhibits stability against varying pressure, and sustains high repeatability over the pump’s entire lifetime.
A wide selection of available head materials allows the transfer of all liquids, whether neutral or aggressive, and the pump can mount in any position using either a manifold or tubing. Accessories include pressure-control valves and pulsation dampeners.
KNF Neuberger Inc.
2 Black Forest Rd.
Trenton, NJ 08691
(609) 890-8600
© 2013 Penton Media, Inc.
