Hydraulic toolholder
April 9, 2013
The Tendo E compact hydraulic toolholder eliminates the need for different holder technologies for milling, drilling, and reaming.
The Tendo E compact hydraulic toolholder eliminates the need for different holder technologies for milling, drilling, and reaming. The toolholder safely transfers torques up to 520 Nm (384 lb-ft) at a 20-mm clamping diameter and is suited for high-volume cutting.
The Tendo E compact has vibration damping and precise run-out accuracy of less than 0.003 mm (0.0001 in.) at 2.5 × D, which protects the machine spindle and cutting tool from damage. In roughing operations, tools can be quickly changed with an Allen key.
Schunk
211 Kitty Hawk Dr.
Morrisville, NC 27560
(919) 572-2818
© 2013 Penton Media, Inc.
