Posital Ethernet/ IP absolute rotary encoders install easily via a switch that supports daisy-chain or device-level rings. The encoders can be programmed quickly with assistance from six diagnostic LEDs. Programmable parameters, a velocity filter, and an “endless-shaft” mode result in more efficient processes. The units are ODVA certified and feature up to 16-bit resolution and 14-bit revolution.
Fraba Inc.
1800 E. State St., Suite 148
Hamilton, NJ 08609
(609) 750-8705
www.posital.com
Aug. 29, 2024
Aug. 28, 2024
