Disc springs
Conically-shaped disc springs are washer-type components designed to be axially loaded.
Features & benefits
  • May be used individually or stacked to achieve the deflection required by the application
  • Provide high levels of load and force within a very small space
  • Suitable for critical applications such as safety valves, clutch and brake mechanisms for elevators and heavy equipment, and supports for industrial pipe systems
SPIROL International Corp.
(860) 774.8571
SPIROL.com
