Inductive-ring sensors
Sept. 1, 2011
A new generation of inductive ring sensors can monitor in-feed of small metal parts.
Features & benefits
  • Easy to install, can be mounted side-by-side or stacked
  • Available in 10, 15, and 25-mm diameter openings; sensitivity adjustment, output-signal duration adjustment
  • M12 connector; one LED for power, and one for function indication
  • Suitable for detecting nails, screws, welded studs, or similar items; ejection monitoring; part counting; wire-breakage monitoring; jam detection of feed tubes, and other applications
Balluff Inc.
(800) 543-8390
balluff.com/BES
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
