Touch-panel computers
Sept. 1, 2011
Touch-panel computers NI TPC-2206 and TPC-2212 touch-panel computers can be programmed with NI Labview for use as HMIs and a 1.33 GHz Intel Atom processor
NI TPC-2206 and TPC-2212 touch-panel computers can be programmed with NI Labview for use as HMIs — and a 1.33 GHz Intel Atom processor imparts performance and extended operating temperature.
Features & benefits
  • -20° to 60° C operating temperature, 4-GB solid-state drives for reliable operation under vibration; Windows Embedded OS for long-term deployment and support
  • 1 GB of RAM, Ethernet ports, LED backlight to maintain screen brightness across range of temperatures
  • Compatible with NI CompactRIO, PXI, NI Smart Cameras, NI Embedded Vision, and other industrial devices
  • LabVIEW graphical development environment allows communication with hardware through TCP, OPC, USB, Modbus, Ethernet/IP
National Instruments
(512) 683-5090
ni.com/products
