Linear power transmission
Feb. 1, 2012
The High Performance Linear System RP+ and RPM+ from WITTENSTEIN Inc. are precision rack and pinion designs.
• RP+ Linear System combines the alpha TP+ gearbox, pinion and rack into one optimized solution for linear motion • RPM+ Linear System combines the TPM+ actuator, pinion and rack; the system is highly dynamic and suited to linear applications that use rack and pinion technology • Maximum power density and functional design in a unit featuring visible length benefits with a compact design • 120% more feed force, 50% higher system rigidity, 100% higher power density, 15% more positioning accuracy
(888) 534-1222 / wittenstein-us.com
Feb. 7, 2025
Feb. 7, 2025
Feb. 7, 2025
Feb. 7, 2025
