V-belt drives
July 1, 2011
Premium V-belt drives with high power density stretch significantly less than standard cross sections, suitable for use on problematic drives requiring high-impact strength and load-carrying power.
Features & benefits
  • Premium belts can replace several standard belts; banded belts feature a multiple-layer tie band for lateral rigidity to prevent them from turning over or coming off the drive
  • Premium Singles are for applications where banded belts cannot be used; may be used with deep groove sheaves and drives with limited room for take-up
  • Non-rubber surface cover allows momentary slippage due to excessive overloads without damaging belt; double fabric cover provides maximum abrasion resistance
  • Sheaves available with capacities to 600 hp and bore sizes from ½ to 8½ in.
TB Wood's Inc.
(888) 829-6637
tbwoods.com/premiumbelts.asp
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
