Retaining Nuts
June 1, 2010
SHOELOK hardened steel, mechanical lock retaining nuts adjust, preload, and secure bearings and other components to shafts and spindles of power assemblies.
Features & benefits
  • Centerline alignment; develops peripherally when setscrews (turned with hex drive wrench) force shoes into deep thread contact
  • Sufficient radial clearance needed to turn set screws; useful in heavily loaded applications where shock and vibration are present
  • Metric series made with ISO metric threads with stringent tolerances; IDs from 23.8 to 232.7 mm; holds axial loads from 95 to 2,231 kN
Whittet-Higgins Co.
(401) 728-0700
www.whittet-higgins.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
