Drive system
March 1, 2012
The Servo Inverter i700 from Lenze Americas Corp. is suitable for simple positioning tasks as well as highly dynamic, precise multi-axis applications in handling and packaging machines or robot applications.
• Extremely short cycle times • 32-bit signal resolution • Overload capacity more than 200% percent • Single-axis and double-axis modules offer power from 0.37 to 15 kW, along with appropriate power supply modules • Plug connectors enable easy wiring
(800) 217-9100 µ lenzeamericas.com
