Grounding cable accessory
April 1, 2010
SKINTOP MS-M BRUSH gland offers a low-resistance 360° screen contact; for full grounding coverage, EMI interruptions and equipment failure are eliminated
SKINTOP MS-M BRUSH gland offers a low-resistance 360° screen contact; for full grounding coverage, EMI interruptions and equipment failure are eliminated.
Features & benefits
  • Quick, reliable alternative to traditional EMI spring contact cable gland; thousands of brush strands in a circular arrangement provide wider clamping range, making assembly and installation simpler
  • Easy adjustment of cable during installation: Simply insert cable into gland, slide screening braid under brush, turn to close — cable is automatically centered, fixed, strain relieved, and sealed to IP68
  • Suitable gland for all copper screened cables with large cross sections; M25X1.5 to M110x2.0, accommodates cables from 0.354 to 3.858 in.
  • Larger sizes feature dual lamella clamping cage for stability and reliability
Lapp USA (800) 774-3539 www.lappusa.com/safer.htm
