Air-engaged clutch brake
May 1, 2010
Flange Mounted Clutch Brakes Enclosed (FMCBE) nickel-plated models include NEMA standard 1.26.5 (IP 54) version
Flange Mounted Clutch Brakes Enclosed (FMCBE) nickel-plated models include NEMA standard 1.26.5 (IP 54) version and BISSC-version with optional Air Champ locking key for high cycling.
Features & benefits
  • Withstand washdown in bakery and food processing; resist corrosion and bacteria buildup; handles 2-hp motors; nickel-plated sizes can handle up to 10-hp motors
  • Stainless output shaft — captive key and stainless fasteners; double-acting piston prevents overlap of clutch and brake functions; optional nickel-plated input unit and foot mounts for right-angle drives; eliminates costly keyway damage, boosts connection torque
  • Locking bar system prevents the key on output shaft from tipping in keyway, secured with a setscrew; optional C-faced adaptor for foot-mounted applications
Nexen Group Inc.
(651) 484-5900
nexengroup.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
