New Products
April 1, 2009
Transducer-quality strain gages Custom and OEM strain, linear, double-shear, bridge, Karma, and diaphragm gages made to order in batches from $200 or
Custom and OEM strain, linear, double-shear, bridge, Karma, and diaphragm gages made to order in batches from $200 or standard in stock.
Features & benefits
  • Dual shear gage SGT-2d/350M-SY41 from $3.70, Constantin foil, 5 µm thick, polyimide carrier, 350 Ω resistance
  • Linear gage SGT-L3I/350I from $1.45, 20 µm thick, 0.75 × 0.75-mm grid, 2.75 × 2.75-mm polyimide carrier
  • T rosette gage SGT-2/350-XY41 from $3, 20 µm thick, 1.6 × 1.8-mm grid, 4.9 × 5.8-mm polyimide carrier
  • Additional units available from stock delivery; accessories include bridge balancing, zero-temperature compensation resistors in nickel or Constantin with 2 to 5 Ω; other foils for 10 to 60 Ω, encapsulated or open face
  • Bondable terminal pads from $0.03 per pair; BTP, BTPB, BTPD, BTPC, BTPE available
Omegadyne Inc.
(800) 872-3963
www.omegadyne.com
Circle 160
Chains and sprockets
Chain drives manufactured to ANSI specifications, and teeth are machined after chain rows are in place for longer life.
Features & benefits
  • High carbon steel, no “A” plates on multiples or inserted finished hub design; runout and side wobble are minimal, within tolerance
  • Extended and 24-hour service and engineering support
Martin Sprocket and Gear Inc.
(817) 258-3000
www.martinsprocket.com
Circle 161
Heavy-duty encoder
MR316 ZapFREE heavy-duty fiber optic rotary encoder is designed for harsh and hazardous environments.
Features & benefits
  • For use in ATEX-type Group I/II hazardous locations, 90-mm encoder housing, large 12-mm shaft, heavy-duty bearings and IP66 shaft seals
  • Remote encoder link up to 1,000 m, extended temperature option for -60° to 150°C
  • System offers combination of incremental encoder, multiturn absolute position sensor, and tachometer
Micronor Inc.
(805) 499-0114
www.micronor.com
Circle 162
Electric clutches
Electric clutches are designed to mount right onto an engine shaft and take the vibration and temperature from small gas or diesel engines.
Features & benefits
  • Can either drive components directly or through a belt
  • A variety of stock pulleys available; custom design service as well
Ogura Industrial Corp.
(732) 271-7361
www.ogura-clutch.com
Circle 163
Backlash free couplings
SKF-5000 backlash-free torque limit couplings accommodate more than double the torque of older models.
Features & benefits
  • Array of torque-limiting elements, limiter handles torques to over 4,000 lb-ft; transmittable and disengagement torque is dependent on the clutch's OD as well as the number of torque-limiting devices used
  • Unlike conventional limiters, can be reengaged through tightening of screws instead of with hammer
R+W America
(630) 521-9911
www.rw-america.com
Circle 164
Linear magnetic encoders
LM10 linear encoder offers value and up to 100 m measuring length.
Features & benefits
  • Solid-state, noncontact design, IP68 readhead rides at 0.1 to 1.5 mm standoff over self-adhesive magnetic strip scale; 5 µm resolution at 20 m/sec and 1 µm at 4 m/sec positioning
  • Integral setup LEDs, wide installation tolerances; scale is available either “cut to length” or in lengths of up to 100 m
  • IP68, 20° to 85°C; velocity to 25 m/sec at sinusoidal output; digital models to 25 m/sec for 100, 50, and 10-µm resolution
Renishaw Inc.
(847) 286-9953
www.renishaw.com/encoders
Circle 165
Linear modules and actuators
eCKK and eCKR Compact modules offer maintenance-free operation through lubricated bearings, integrated stepper motor with positioning control, configurable 3D CAD generator, and hybrid eLINE ball rail guideways.
Features & benefits
  • Easy programming and startup, available in both ball screw-driven (eCKK) and belt-driven (eCKR) versions, in profile sizes of 90 and 110 mm
  • Integrated eLINE Ball Rail hybrid guideways combine weight advantages of Al with toughness of hardened steel inserts; higher moment, load capacities than single-rail solutions
Bosch Rexroth Corp.
(800) 322-6724
www.boschrexroth-us.com
Circle 166
Couplings for high-stress applications
CD Couplings are suitable for use with fixed displacement hydraulic pumps driven by servomotors.
Features & benefits
  • Pump systems utilize power and precision of servomotors … pressure is controlled by modulating pump output volume with high-performance controls and CD shaft coupling
  • Composite material withstands punishment and stress of servomotor; single flex models torque-capacity range from 40 to 1,436 Nm and beyond with speed ratings from 4,400 to 17,000 rpm
  • Environmentally friendly and RoHS compliant
Zero-Max Inc.
(800) 533-1731
www.zero-max.com
Circle 167
Gearmotors, motors, speed control
A new line of 12 V PMdc gearmotors, motors, and dc motor speed control is available for low voltage, battery powered, remote location, or solar applications.
Features & benefits
  • 12-V PMdc gearmotors and motors available in 24A and 33A frame sizes; hp from 1/50 to 1/8 hp; able to generate up to 310 lb-in. torque; custom models available
  • Type WPM-12 Vdc speed control is suitable for applications that require basic, single-direction speed control
  • PWM speed control provides cool motor operation, long brush life, low noise, and wide speed range
Bodine Electric Co.
(773) 478-3515
www.bodine-electric.com
Circle 168
Heavy-duty linear thrusters
T4 Thrusters offer ultra smooth actuation and twice the static load-carrying capability of T series thrusters.
Features & benefits
  • Black anodized body, precision recirculating ball bearings
  • Four guide shafts double load-carrying capacity of previous models and reduce deflection
  • Available in 2, 2.5, and 3-in. bores; standard stroke lengths of 1 to 12 in. increments; strokes up to 36 in. also available
  • Air cushions, internal and external bumpers, and magnetic position sensing available as options
Bimba Manufacturing Co.
(800) 442-4622
www.bimba.com
Circle 169
Integrated servomotors
SM2316D-PLS2 and SM2316DT-PLS2 servomotors are complete servo systems with built-in controller, amplifier, and encoder.
Features & benefits
  • Higher encoder resolution (4,000 cpr) offers smoother velocity and tighter position control than previous models
  • Enhanced trajectory overshoot braking functions stop large loads quickly
  • High-speed position capture input enables < 5 msec registration
  • SM2316DT-PLS2 delivers more than 200 W continuous shaft power
Animatics Corp.
(408) 748-8721
www.animatics.com
Circle 170
Digital torquemeters
MCRT 86000V and 87000V series bearingless digitial torquemeters tolerate rotor to stator misalignments of 1 in. axially and 0.3 in. radially.
Features & benefits
  • Mechanical overload ratings of 400%; 0.05% accuracies; 300% electrical overrange
  • Full scale ranges from 50 to 10,000 Nm available
  • Analog, frequency, and digital outputs
  • High immunity to EMI noise, ISM emitters, and closely spaced similar meters; rated for use with variable frequency drives
S. Himmelstein & Co.
(847) 843-3300
www.himmelstein.com
Circle 171
IP67 limit switches
MP730 through MP760 sealed limit switches connect through an M12×1 connector to maintain IP67 protection.
Features & benefits
  • Can be mounted on the side, bottom-mount option also available
  • Metal housing, 5-pin connector, or plastic housing and 4-pin connector
  • Mounting holes either 20 or 25 mm apart for installation flexibility; actuator options
  • Conform to IEC 947-5-1 and EN 60 947-5-1
Microprecision/Wilbrecht LEDCO Inc.
(888) 323-8751
www.microprecision.us
www.wilbrechtledco.com
Circle 174
Non-stiction air cylinders
Airpel non-stiction air cylinders now include a position sensing option: non-contact electronic switching sensors from Sick Inc., using giant magneto resistive (GMR) technology.
Features & benefits
  • For electrical output of piston position, most Airpel models are offered with optional switch-activating magnets on the piston, plus one or more optional aluminum tracks attached to the cylinder
  • Tracks designed for easy mounting of the GMR position sensors
  • Sensors operate at 10 to 30 Vdc with repeatability less than 0.2 mm
  • PNP or NPN output; extension cables available in 2 and 5 m lengths
Airpot Corp.
(800) 848-7681
www.airpot.com
Circle 172
Compact linear actuator
Motorized linear actuator LSMA-160-300 provides precision travel up to 300 mm and is driven by a brushless servo or stepper motor with a precision-ground ballscrew.
Features & benefits
  • Low profile, high stability, compact design
  • Resolution to 0.1 µm; load capacity to 10 kg
  • Table height 37 mm; straightness of 5 µm
Intellidrives Inc.
(215) 728-6804
www.intellidrives.com
Circle 173
Integrated motor and driver
The MDrive line now offers a quad stack NEMA size 23 brushless 1.8° stepping motor that delivers speed-torque comparable to a single stack NEMA 34, but with a 33% smaller footprint.
Features & benefits
  • MDrive23Plus with quad stack motor capable of full (256 × 200) microstepping with a 12 to 60 Vdc integrated driver
  • Three versions available: Microstepping with step and direction input, Motion Control with intelligent programmable controller, and Speed Control with velocity controller
  • Operating range of -40° to 85° C
  • Options include encoders, planetary gearboxes, startup kits, and cables
Intelligent Motion Systems Inc.
(860) 295-6102
www.novantaims.com
Circle 175
Torque motors
TMK high speed, iron core torque motors feature a new electromagnetic design that increases continuous torque by 30% and speed up to 350% over classical torque motors.
Features & benefits
  • Available in 12 sizes; external diameter from 198 to 385 mm; peak torque to 2,240 Nm
  • Maximum rated speed to 5,170 rpm; increased resistance to dirt and oil
  • New motor design increases torque as a result of a flux-concentrating structure; laminated rotor structure and optimized rotor teeth increase speed
ETEL Inc.
(847) 519-3380
www.etel.ch
Circle 176
Linear guides
The HA Series of high-accuracy linear guides provides high motion accuracy, rigidity, load capacity, and improved dust resistance.
Features & benefits
  • High motion accuracy is achieved through the use of ultralong ball slides in both narrow and wide ranges; unique design of the guide's ball-recirculation components permits smooth ball movement and minimal passage vibration
  • Number of balls in the unit have been increased to improve rigidity, load capacity, and friction
  • Rail deflection is reduced through increased counterbore depth of the rail-mounting hole
NSK Precision America
(800) 255-4773
www.nskprecision.com
Circle 177
