Ethernet patch cables
July 1, 2010
Straight and crossover Cat5e Ethernet patch cables, in eight colors and 3 to 50-ft lengths, support up to 1,000 Mbps.
Features & benefits
  • Cables reduce EMI effects with single metal foil shield wrapped around entire set of four twisted shielded pairs
  • RJ45 connectors also shielded against electrical interference; 350-MHz cables exceed Cat5e TIA/EIA standards, reduce impedance and structural return loss (SRL), compared to standard 100-MHz cables
AutomationDirect
(770) 889-2858
www.automationdirect.com/ethernet
