Fluid-circulation heaters
Dec. 1, 2011
AHPF Series air-process and liquid-circulation heaters raise temperatures of air, gas, water, or aqueous solutions with air or gas flow to 15 cfm and air or gas output temperature to 430° C.
Features & benefits
  • 316 stainless steel, pressures to 100 psi and 50 W/sq in
  • For use where clean air is necessary, such as in laboratories, environmental testing areas, and packaging and sealing
Omega Engineering Inc.
(800) 826-6342
omega.com/ppt/pptsc.asp?ref=AHPF_HEATER
