STH planetary gear reducer and servodriven rotary actuator includes a secondary offset 85-mm hollow-bore rotary stage that allows wiring, tubing, and ballscrews to pass through.
Features & benefits
Planetary-gear-reducer portion mounts to nearly all small to medium-duty servomotors; sizable for 12:1 through 324:1 ratios
Large cross-roller bearings allow for thrust loads (to 800 lb) and torsional stiffness
Useful in indexing tables, dispensing assemblies, robot end-effectors, and automated assembly equipment
Nidec-Shimpo America Corp.
(630) 671-2167
shimpodrives.com
