Rack for linear motion
July 1, 2011
The case hardened Performance Class Rack connects with a High Performance Linear System gearbox or actuator and pinion for greater efficiency and optimal performance.
Features & benefits
  • Value Class (low-duty applications); Smart Class (mounting flexibility); Premium Class (high-duty applications)
  • Performance Class in standard hole pattern or pattern for high feeding forces; case hardening provides strength at the tooth root of the rack, for resistance to high stresses and transmission of higher feeding forces
  • Linear System doubles performance with less space; boosts efficiency, power density, and accuracy
WITTENSTEIN Inc.
(888) 534-1222
wittenstein-us.com/contact/online-request-for-engineering.cfm
v
March 18, 2025
March 18, 2025
March 18, 2025
March 18, 2025
