TIM Series non-contact, rod-style linear position sensors are designed for integration in hydraulic and pneumatic cylinders.
Features & benefits
Easily mounted in-cylinder through one end and attached to cylinder with either a threaded flange on the rod or a plug-in flange; screw-plug hole is sized at M18 diameter and plug-in flange is 48 mm; magnetic pick-up position marker is mounted on application's piston rod
Available in stroke lengths from 50 to 2,500 mm; custom lengths available for volume applications; operate under pressure to 350 bar with peaks to 530 bar; shock and vibration ratings are 100 and 25 g respectively
Novotechnik U.S. Inc.
(508) 485-2244
novotechnik.com
