PWM servo controller
Nov. 1, 2011
ESCON 36/2 DC is a 4-quadrant, digital PWM servo controller for use with dc motors up to 72 W.
Features & benefits
  • Drift-free yet dynamic speed behavior enables a speed range of 1 to 150,000 rpm; fully configurable digital and analog inputs and outputs; can be run in various operating modes — speed controller (closed or open loop), current controller
  • Controlled by an analog set value; specified by analog voltage, external or internal potentiometer, defined value, or PWM signal with variable duty cycle; speed can be regulated with a digital incremental encoder
  • When connected to a PC via a USB port, can be easily configured with the graphical user interface
  • Protects against over-current, excess temperature, under and over-voltage, transients and motor cable short-circuits; 95% efficiency
maxon precision motors inc.
(508) 677-0520
maxonmotorusa.com
March 18, 2025
March 18, 2025
March 18, 2025
March 18, 2025
