Positioning controller
March 1, 2011
The EPOS2 24/2 miniaturized positioning controller is designed for commanding and controlling in the CANopen network, with USB and RS-232 available as
The EPOS2 24/2 miniaturized positioning controller is designed for commanding and controlling in the CANopen network, with USB and RS-232 available as further communication interfaces.
Features & benefits
  • Operating modes include position, velocity, and current; suitable for automation technology, tool building, and in mechatronic-drive systems
  • Functions include step/direction mode for incrementally controlling motor-shaft movement or master encoder mode for applying the drive as electronic gearing; commanding through an analog set value voltage may replace conventional servoamplifier applications
  • Dual-loop position and speed controller; Interpolated Position Mode allows synchronous path following
  • Current, speed, or position controls can be set through enhanced regulation tuning
maxon precision motors inc.
(508) 677-0520
maxonmotorusa.com
