iPad-controlled miniature hexapod
Nov. 1, 2011
The M-811.STV vacuum-compatible Hexapod six-axis positioner comes with software and a highly specialized controller.
Features & benefits
  • Small size with high load capacity and high accuracy; travel ranges of 34 × 32 × 13 mm, 42° rotation, load capacity to 5 kg, 40-nm actuator resolution
  • Minimum incremental motion to 200 nm, repeatability to ±0.2 µm, and 10-mm/sec velocity; both the M-810 and M-811 models can be controlled by an Apple iPad
PI (Physik Instrumente) L.P.
(508) 832-3456
pi-usa.us
