Caliper brakes
Dec. 1, 2010
Spring-engaged, hydraulically disengaged brakes are for dynamic braking and static holding.
Features & benefits
  • Withstands temperatures to -30° F, unlike pneumatically actuated counterparts that withstand only 0° F
  • Fixed-point pivots for equal braking force to both rotor sides; various friction materials
  • Quick-release pins allow easy brake shoe removal from actuator arms for friction-pad replacement
  • Nested spring design minimizes spring-force losses
  • Ports with large Cv values ensure fast actuation, even when the hydraulic fluid is at lower temperature.
  • Disengagement pressures: 75 to 1,500 psi
Nexen Group Inc.
(651) 484-5900
nexengroup.com
Continue Reading
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
