The CoDeSys embedded controller, for use with the CPX Series of multifunctional control terminals, is an IEC 61131-3 compatible programming environment.
IEC 61131-3 users can port over existing code, libraries, and function blocks, reducing programming time
Six programming languages from CoDeSys let users select one that is most comfortable for the programmer in a particular application
CPX-CEC module handles single and multi-axis applications and operates autonomously or in conjunction with a host controller, such as a master PLC; serves as intelligent slave in fieldbus-based systems, for localized signal preprocessing
Festo Corp.
(800) 993-3786
festo.com/cms/en-us_us/3112.htm
March 18, 2025
March 18, 2025
March 18, 2025
