Control panels
March 1, 2012
Series CNI-CB120SB self-contained temperature control panels from Omega Engineering Inc. provide a complete control system, eliminating the need to select and assemble separate components.
Control panels
• Preconfigured panels are ready to install, requiring only supply power, load, and sensor hook-up • Equipped with an Omega iSeries microprocessor-based controller with on/off, PID, and ramp/soak capabilities along with a tricolor display • Panels are supplied with a thermocouple input jack and M12 female connection for RTD or process inputs • Compact packaging makes panels portable and easy to mount, even in limited spaces • Suitable for chemical and food industries
(800) 826-6342 µ omega.com/pptst/CNI-CB120SB.html
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
