Shaft grounding ring
June 1, 2010
The AEGIS 841 SGR bearing isolator ring protects severe-duty motor bearings from harmful VFD-induced shaft currents and from contaminants.
Features & benefits
  • IEEES standard 841-2001 calls for protection of bearings from VFD-induced currents in addition to bearing seals
  • Bearing seals provide only half the protection needed by VFD-controlled IEEE 841 and other severe-duty motors; SGR combines shaft grounding ring and non-contact IP56 bearing isolator that withstands dust and water jets
  • Anti-Clog slinger drain system prevents dirt and debris from plugging up drain; slinger chops and ejects foreign matter
Electro Static Technology
(866) 738-1857
www.est-aegis.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
