AC/DC power supply
Aug. 1, 2011
The PHI 3K Series industrial-grade ac/dc switching power supply generates up to 3 kW of output power.
Features & benefits
  • Power-factor-corrected input converts 400 Vac input (340 V to 480 Vac operating range) to 200 Vdc/15-A or 400 Vdc/7-A continuous output, with fan cooling
  • Built-in redundancy diode separates internal modules, allowing units to be connected in parallel for higher output power, N+1 redundancy, or to create a three-phase high-power system
  • Conformal coating protects against moisture, humidity, airborne contaminants, and high voltage; other protection features include input-to-output isolation of 4,300 Vdc, continuous current limiting with short-circuit protection, and thermal protection
Absopulse Electronics Ltd.
(613) 836-3511
absopulse.com
