Retaining rings
March 1, 2012
A new parts and engineering catalog featuring more than 10,000 products is now available from Smalley Steel Ring Company in both paper and PDF formats
A new parts and engineering catalog featuring more than 10,000 products is now available from Smalley Steel Ring Company in both paper and PDF formats.
• Catalog combines the existing Spirolox Retaining Ring and Wave Spring series with newly released series including Hoopster Retaining Rings, Constant Section Rings, Metric Wave Springs, and Small Series Wave Springs • Spirolox rings are interchangeable with ordinary stamped retaining ring grooves and require no special tooling for removal • Wave Springs reduce heights by up 50% with the same force and deflection as standard coil springs and fit in tight radial and axial spaces • Carbon and stainless steel parts available from 0.25 to 16 in.
(847) 719-5900 µ smalley.com/getcatalog
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
