Control system eases food processing
Aug. 4, 2008
Movifit Field Integrated Technology, a decentralized control system designed for food and beverage processing, is available in both hygienic IP69K-rated and standard IP65 construction
Movifit Field Integrated Technology, a decentralized control system designed for food and beverage processing, is available in both hygienic IP69K-rated and standard IP65 construction. Preconfigured routines for conveyor applications provide ready-to-use functions that simplify programming. Protected by a special surface coating that repels liquids, the self-draining housing is unaffected by cleaning agents. A dual-chamber design houses electronics and communications in one chamber, and connection and mounting technology in the other. An inner seal protects power electronics against humidity.
SEW-Eurodrive
www.seweurodrive.com
(864) 439-8792
